Post Your Battery Stats W/display Usage Rzr Hd/hd Maxx
Posted 13 November 2012 - 02:44 PM
Posted 13 November 2012 - 02:49 PM
As the topic says, lets see what you boys are getting. I'm loving this damn phone.
I'm running the jellybean leak, new nexus camera and it's rooted of course. Nothing else has been done to the device.
Posted 13 November 2012 - 05:10 PM
Dang dude. Do you like do nothing with your phone! LOL I'm just happy to get a day out of mine. But that usually doesn't happen. I constantly use mine.
Posted 30 October 2013 - 05:56 AM
Running stock 4.1.2 ota 9.18.29 rooted with motochopper. Here's a screenshot of BBS.
Its just weird that my razr seems cannot get into deep sleep because of wifi running most of the time. Still cannot identify the culprit causing the wifi always running. Any comments are greatly appreciated guys...
Posted 30 October 2013 - 05:58 AM
Here you go...
Posted 30 October 2013 - 05:59 AM
Posted 30 October 2013 - 06:13 AM
Any other suggestion? Maybe i missed other setting?
Posted 30 October 2013 - 06:32 AM
Posted 30 October 2013 - 12:14 PM
Sent from my Ultra Maxx HD running Team OSE Rom
Posted 30 October 2013 - 07:46 PM
i found out the culprit !
the wifi running is caused by active smart action that use location service, so i turn off smart action and solve the wifi problem
will monitor battertstats again today...
Posted 02 November 2013 - 02:20 AM
so after benchmarking battery with various tools i found out that :
1. the OS is really affecting battery life. i downgraded my OTA 9.18.79 to stock 9.16.6 which seems to be more stable imo. As far as the app, they run just as smooth and snappy as 9.18.79. No visible performance difference. DONT FORGET! to root and install Titanium Backup to freeze Updater.apk after downgrade or you will keep receiving update notification from Verizon. (You can also force stop Updater in Setting -> App if you dont want to be rooted)
2. the carrier simcard also affecting battery life. I used several sims including GSMs and found out that older SIMs (1x not EVDO) seems to make the RAZR MAXX HD warmer thus draining battery more than newer version SIMs (EVDO).
3. Location service doesnt affect battery life significantly. I ended up turned on the feature all day long.
4. Turning on Wifi while there's no wifi connection also doesnt affect battery life. I benchmarked battery life while using mobile data for connection with wifi turned on all the time. Reception in my location ranges from -61 dbm to -85 dbm. Blue 3G logo is displayed on the status bar all the time except when receiving calls or texting.
5. Smartaction can affect battery life depending on your trigger actions. if you use location service as your trigger action, the app will trigger location service all the time not allowing RAZR into deep sleep. So be smart setting up your trigger action.
i will post my battery life screenshot after taking those above factors. My RAZR MAXX HD is running stock 9.16.6 WITHOUT any mod, except root (and TitBack) to freeze Updater.
Good luck tuning up your RAZR MAXX HD. I luv this device for its unbeatable performance and sleek design. Battery life, nice display, fast processor, big ram, big storage, whats not to love ? the camera sucks i can give you that, but i rarely use camera on my phone. I'm a photographer by trade by the way
Posted 02 November 2013 - 02:58 AM
