Boot Sound
4 replies to this topic
#1 gregspruce
gregspruce
  • 5 posts
Posted 14 November 2012 - 04:31 AM
Is anybody else having an issue where the boot sound plays regardless of the ringer volume on shutdown?
#2 RangeOfficer452
RangeOfficer452
  • 50 posts
Posted 14 November 2012 - 06:12 AM
They all do that, always have. At least on all the Droid's I've owned. (OG Droid, X, Droid W, Bionic, RAZR, RAZR HD Maxx)
#3 gregspruce
gregspruce
  • 5 posts
Posted 14 November 2012 - 06:16 AM
Usually, having the phone in silent/vibrate mode when you turn it off works. (verified on OG Droid, Incredible, Bionic, OG Razr, and SOMETIMES on the maxx hd)
#4 RangeOfficer452
RangeOfficer452
  • 50 posts
Posted 14 November 2012 - 06:23 AM
nope I can honestly say it has absolutely nothing to do with the booting up volume. Someone correct me if I'm wrong but I believe when the phone is booting up it has its own sound/volume that can't be changed unless you manually go in and delete/change files. hence there are some ROMs that have extremely loud music or sounds that play and you cannot change that unless you delete the file.
#5 gregspruce
gregspruce
  • 5 posts
Posted 14 November 2012 - 08:38 AM
Guarantee it does for the majority of moto's droid line double-extra certain for the OG droid and Bionic, I'll correct you where you're wrong sorry, sounded like a jerk. Got it fixed on my Maxx HD, doing a hard reboot (pwr and vol-) ignores your volume settings and plays the sound. When the phone is turned off normally (holding down pwr, selecting power off) and turned back on normally, it suppresses the sound.
