I actually used the CWM Touch to delete EVERYTHING from my XT912. I can get to android recovery and I can use AP fastboot, but RSD and Matts Utility wont recognize my phone on AP Fastboot. RSD will recognize phone on BP SPF Fastboot. If i try and flash then it says "failed switching to AP Fastboot"
Thanks For anyhelp. ive been stuck for days. i have the battery issue solved i think i just need rsd to recognize in ap fastboot and id be ok but i dunno??
david
Need Help Bricked Razr
Posted 17 November 2012 - 01:13 AM
- django likes this
Posted 17 November 2012 - 11:05 AM
Posted 17 November 2012 - 11:12 AM
Posted 17 November 2012 - 04:05 PM
Device is locked. STATUS CODE:0
BATTERY OK
ONNECT TO USB
DATA CABLE
If you can get me out of this, my donations will be very merry this year!
Posted 17 November 2012 - 05:21 PM
My phone is doing the exact same thing as Django. I booted into ap fastboot and it says
BATTERY OK
ONNECT TO USB
DATA CABLE
This is exactly what your phone should say. If you are trying to fix something connect it to computer and run matt's RAZR utility.
Posted 17 November 2012 - 05:34 PM
SeNt FrOm .......OvErFlAsHeD SPYDER Xt912
Posted 17 November 2012 - 08:51 PM
ok if you were on Ginger bread use utility 1.6 and extract it to a folder on your desktop then connect via usb install drivers and then fastboot.My phone is doing the exact same thing as Django. I booted into ap fastboot and it says
BATTERY OK
ONNECT TO USB
DATA CABLE
if you were on ICS use utility 1.82 and follow the same thing.
if you need help we are all here for you
Posted 19 November 2012 - 04:40 PM
I too bricked my RAZR. I was on the .215 leak and tried to go back to .211 (returning the phone to Verizon). I'm not sure what happened but now I can't get into recovery mode. The device loops past the M, the dead Android and then shuts down. I've tried the 1.7 utility which is what I was using when things went kaka. DriodRazrUtility is now balking at the battery, so I'll charge overnight, try 1.82 in the morning and report back. Any advice is appreciated.
#9 Guest_24v_*
Posted 19 November 2012 - 05:30 PM
- Shacker likes this
Posted 19 November 2012 - 05:38 PM
1.82 is exactly what you need. Make sure you have all of the drivers installed that come with it as well. Option 1 will get you back to stock 211. Although if it is bootlooping, it will probably not take a charge. You will likely need a factory cable at this point.
Success. 1.82 option 1 plus the updated drivers did the trick. I risked trying it when the phone charge (factory cable) reached 50%. Back from dead.
#11 Guest_24v_*
Posted 20 November 2012 - 03:58 AM
Posted 20 November 2012 - 03:35 PM
#13 Guest_24v_*
Posted 20 November 2012 - 03:43 PM
Posted 24 December 2012 - 05:17 PM
was using droid hd room, wanted to go back to safeside to wait for jelly bean; i put it on safeside but i forgot to wipe date/cache/ before restoring factory backup.
now razor is off. when powered on.. just says moto dual core logo and then turns off again. when trying to go into fastb oot mode; it only blinks once-flashing a white line across top of screen. AND pretty sure my battery was around 20% earlier.
any help is greatly appreciated!
richardhll210@gmail.com
Posted 25 December 2012 - 11:04 PM
Thank you Rhetoric for keeping me in the game. Now I go to try to reinstall Eclipse 1.3 and probably end up bootlooping again.
Edited by koreanschoolkid, 26 December 2012 - 02:04 AM.
Posted 26 December 2012 - 03:40 AM
my prblem seems alot worse than the others
first question.... probably the most important for right now.... will it take a charge when powered off?
