I bricked my phone like i've done many times before but battery ran out when i was ready to use RSDLite to flash either of my .sbf files, (Clockwork Recovery 2.5.0.1 & SPRecovery_ESE81.sbf). Now i'm stuck not having the "ok to program" in fastboot.
I tried the suggested solutions i could find on various forums, but no luck.
Then came to the last resort, which is charging via my usb>micro usb cable,
which i cut in half and isolated the black and red wires,
ready to connect them to + and - behind the backcover of the phone.
Got started and realized my phone has a protective cover,
bought all the neccesary tools during this week.
I find that i can't get to the + and - because of the protective cover,
which is a part of the entire phone and not removeable as far as i can see.
Phone: Motorola Razr MAXX with EB40 Battery and International GSM (I'm from Denmark)
Can't quite figure out what model it is, XT910, XT912 or XT916.
After a long time searching i haven't found any dissasembly guide with the protective cover installed.
Could sure use some help, either removing the cover without destroying my phone
or a software based solution to charge the battery.
[Q] Charging Battery (EB40) Directly - Disassembly - Razr MAXX
Mojo_69
, Nov 17 2012 03:58 AM
1 reply to this topic
Posted 17 November 2012 - 03:58 AM
Posted 17 November 2012 - 05:56 AM
Turns out the visible plastic when the backcover is off, is an internal frame that needs to come out to gain access to the battery + and -
It's extremely tricky.
The seperation is between the plastic and what would seem to be the glass in front.
I used a few homemade plextors made out of hard plastic. After about 20 minutes of fiddling and gaining confidence to use a bit more force it came off and it's currently charging.
Just an FYI if anyone is ever in the same situation.
-Mojo_69
-Mojo_69
