i know on the GB/ICS roms you just added a ogg sound file to the system--> media where the bootanimation.zip was and it worked but i dont see where to add it on JB the system folder is still there but if you put a sound in there it does not works does anybody now if its even possible
JB/CM10 boot animation sound
kalkat579
, Nov 19 2012 03:37 AM
3 replies to this topic
Posted 19 November 2012 - 03:37 AM
Posted 19 November 2012 - 07:04 AM
Boot animation sound is controlled by the Desc.txt file in the bootanimation.zip file. You would have to extract it and create a part for the sound, then put it back into the zip.
Sent from my DROID RAZR
Posted 19 November 2012 - 12:13 PM
what would i need to add to it?
Posted 19 November 2012 - 06:36 PM
Extract the bootanimation.zip file and look at the Desc.txt file. Instructions are inside the file if the Rom dev didn't strip them.
