Screen Shot From Razr Maxx System Screen
8 replies to this topic
#1 tml478
tml478
  • 33 posts
Posted 25 January 2012 - 06:01 AM
Removed
#2 kklier
kklier
  • 18 posts
Posted 25 January 2012 - 08:54 AM
seems old
#3 tml478
tml478
  • 33 posts
Posted 25 January 2012 - 09:16 AM
Just unboxed it
#4 dipsetdiplomat
dipsetdiplomat
  • 60 posts
Posted 25 January 2012 - 09:23 AM
The kernel looks the same do there shouldn't be any problem with flashing.
#5 naes007
naes007
  • 5 posts
Posted 26 January 2012 - 12:26 PM
I flashed Artic Rom with no problems using the original droid razr instructions. A little issue with data connection at first but it seems to have corrected itsellf. Dont really like all the blue so flashing back to my nandroid backup. Flashig did work fin though.
#6 DarkestSpawn
DarkestSpawn
    Tester
  • 211 posts
Posted 26 January 2012 - 01:12 PM
Im curious on the build date as it is different yet everything else is the same. In the other thread another user said it showed Wed Nov 30 22:23:34 CST 2011 not January 9th
-Beta Mod-
-Grand Master of the Testing-
#7 Erp
Erp
  • 264 posts
Posted 26 January 2012 - 01:31 PM
My build date is Nov 30th too, but I have a normal Droid Razr.
#8 BigJArm
BigJArm
  • 212 posts
  • LocationIdaho
Posted 26 January 2012 - 01:48 PM
If you don't like the blue check out the simplicity theme in the themes section. It works great if you don't like the blue.
#9 Mytchh
Mytchh
  • 42 posts
  • Locationhttp://www.se7ensins.com/forums/members/w-e-l-f-a-r-e.105411/
Posted 27 January 2012 - 05:27 PM
Says Droid RAZR..
