Broken Screen Need Help Reseting Everything Before I Send It Back
6 replies to this topic
#1 E_Double_D_Y_81
E_Double_D_Y_81
  • Current Device(s):Razr HD
Posted 25 September 2014 - 05:06 PM
Ok as it says I broke my screen and I cannot figure out how to master reset it before I mail it back. It is still on because the light flashes at the top and my alarm goes off still everyday, but I already have my new phone and managed to get all my pictures off of it using my computer but im lost on how to master reset it. Im a super noob when I comes to programing or technical talk on the droid or the computer so if any of you have an answer for me that would be much appreciated. I have done some searching on here and I read about rooting or debugging and RSD lite and something else I cannot remember the 3 letters SMK or something maybe.but im still lost and not sure if that the way I need to go.
thanks
Eddy
#2 E_Double_D_Y_81
E_Double_D_Y_81
Posted 25 September 2014 - 05:17 PM
I forgot to say that the screen is totally black and unresponsive so just going to the setting menu or resetting using the power and vol- buttons is not an option that I have been able to figure out.
sorry for leaving out that info
#3 livinginkaos
  • 15,103 posts
Posted 25 September 2014 - 05:56 PM
Do you know how to use fastboot? If so, just power off the device. Boot into fastboot by holding the vol down, tap the power while continuing to hold vol down, then release. Plug in the usb. Open a command window in your fastboot directory. Type: Fastboot erase userdata Done. sent from my G3
#4 E_Double_D_Y_81
E_Double_D_Y_81
Posted 25 September 2014 - 06:05 PM
Thank you for the quick response. im not familiar with fastboot no, but I will do some searching here and find out.
#5 livinginkaos
  • 15,103 posts
Posted 25 September 2014 - 06:17 PM
Btw, what device are you on?
sent from my G3
#6 livinginkaos
  • 15,103 posts
Posted 25 September 2014 - 06:19 PM
If you are on the xt926, you can connect the hdmi, and if necessary a mouse thru an otg.
sent from my G3
#7 E_Double_D_Y_81
E_Double_D_Y_81
Posted 25 September 2014 - 07:22 PM
ok I have the fastboot command thing installed on my computer. im am trying to erase a moto razr hd not sure if it is the xt926. but im not sure how to get it to boot in fastboot because I cannot turn it off since the screen is unresponcive.
