I searche for this but came up empty.............. Feel free to point a link if I missed one.
Pics save by default to my internal card - I'd like them to go to external card. Is there a setting / way to do this?
Picture Storage -External Card
newskate9
, Nov 29 2012 05:48 AM
5 replies to this topic
Posted 29 November 2012 - 05:48 AM
Proud father of a US Marine
Posted 29 November 2012 - 05:58 AM
Open camera in setting there is a tap to select storage location
Posted 29 November 2012 - 06:07 AM
Actually - that is STORE ( not STORAGE ) LOCATION - I think that means that the pic file will store "where you are when the pic was taken". It is an ON/OFF switch, not a selection option.
At least that's how I'm seeing it.
Posted 29 November 2012 - 06:09 AM
is should be there in settings, sorry if I mislead you, always was in the past
Posted 29 November 2012 - 06:19 AM
You are correct, it's the 4th option in the camera settings.
Posted 29 November 2012 - 06:44 AM
OK, brain fart here........... I open camera. I touch the screen to open the options, and the settings icon. There are only 3 item to "pick". I'm on Full Throttle - would this be any different than stock?
EDIT: I went back to stock slot and opened camera - the option to pick storage location is there, #4 down. Maybe I'll change it here, and see if it impacts the other ROM/Slot
EDIT: Nope, that didn't stick.
EDIT LAST: This is camera related - different version on FT vs. Stock. No issues, plenty of memory, I have them all going to dropbox anyhow so I can just delete on some frequency if needed.
