Found a big list of build.prop tweaks for JellyBean
Posted 30 November 2012 - 12:31 AM
Figured I'd post them up for other newbies like myself. Enjoy!
Placing them in my initial de-bloated build and will be testing tomorrow. I'll be using the battery life, phone, and performance tweaks.
I'll report back with results.
Edit: Everything is working properly! So far so good!
- andlaw likes this
#2 Guest_BDH_*
Posted 30 November 2012 - 12:39 AM
I learned the whole "less is more" thing from andlaw. The amount of build.prop tweaks I had in one of my ROMs actually drained battery life and hindered performance.
Also, that thread is posted in the Galaxy Nexus section. Make sure some of the tweaks won't bootloop your phone upon reboot.
- andlaw likes this
Posted 30 November 2012 - 12:46 AM
Try to remember that "less is more." Too many build.prop tweaks can actually hinder performance rather than help it. You gotta make sure you know what you're putting into your ROM and what it does so that some of the tweaks you'll be adding won't conflict with each other. Just some helpful hints to pass along.
Yeah that was the main thing andlaw told me. I'm flashing the ROM now. All I incorporated were the battery and phone tweaks. If I run into any problems, I'll ask that the link be taken down.
Thanks for the advice, man!
- andlaw likes this
Posted 30 November 2012 - 02:02 AM
Posted 30 November 2012 - 05:25 PM
Update: been running these tweaks all day with zero issues.
- andlaw likes this
