Bricked....maybe?
Posted 01 December 2012 - 04:29 AM
Posted 01 December 2012 - 05:09 AM
I restored my HD from the most recent JB leak using matt's utility, however the system will not flash to my phone. it flashes continuously and keeps sending the system over and over again. I attempted to do it manually using the instructions but it did not work. My phone is basically stuck in fastboot right now. RSD will not work, none of the utilities either.
System will appear to repeat several times as it is a large file and is automatically "split" into smaller files while flashing..... the utility wontwork now??... is it giving you error messages?
sent from my tapatalked DROID RAZR....from somewhere between lost and found....
Posted 01 December 2012 - 06:22 AM
At first RSD was saying it was an invalid code the "Getvar" so i attempted to delete the lines like someone had suggested.
The first time it fastbooted, it would not wipe data. The phone froze completely at wipe data.
Edit*
The Fastboot Reason says Sticky Bit Fastboot.
Posted 01 December 2012 - 06:34 AM
If Verizon don't want the old one back... you could send it to me lol jkIt went on for about 10 minutes without doing anything. I went to verizon and they're shipping me a new one by monday. If i can fix this one, ill just re-brick it and keep the new one lol
Edit*
Posted 01 December 2012 - 06:36 AM
Posted 01 December 2012 - 06:38 AM
qe1/1
E:Can't Mount /Cache/Recovery/Caller
Formatting /data...
This is where it got stuck at the first time
i blame ALL of this....on windows 8
Posted 01 December 2012 - 06:47 AM
You may be right about windows 8 lol.... have not seen that error, will look into it.... and yes if you want to part ways with your maxx, I will gladly take it off your handsI flashed with matts utility and it worked now.... but now it says
qe1/1
Formatting /data...
Posted 01 December 2012 - 06:54 AM
Posted 01 December 2012 - 06:57 AM
I'm driving .... so chat is a bit more difficult lolMy buddy has it on ebay right now. im in the chat if you want to chat easier lol
Posted 01 December 2012 - 06:59 AM
Posted 01 December 2012 - 07:01 AM
Always do..... I'm a truck driver :-)Droiding and driving?! nice.... lol
Posted 01 December 2012 - 07:06 AM
Posted 01 December 2012 - 11:32 AM
sweet. it still didnt work on windows 7 / 8
Maybe try using the updated fastboot files.... .... can't hurt to try.... copy and paste into the utility folder (choose "replace" when prompted)....
Posted 01 December 2012 - 11:35 AM
Also .... update your Motorola drivers (if you have not done so already) .... and you are using the OEM USB cable for your phone right?sweet. it still didnt work on windows 7 / 8
Posted 01 December 2012 - 02:42 PM
Posted 01 December 2012 - 02:47 PM
Very good..... so everything is booting normally now? ?yeah, it managed to work i let it sit at the erase data screen for about 10 minutes and it boted.
Posted 01 December 2012 - 02:51 PM
Posted 01 December 2012 - 02:55 PM
For the most part?..... still having some issues? Or too soon to tellyes for the most part
Posted 01 December 2012 - 03:04 PM
Posted 01 December 2012 - 03:07 PM
Well if you are using TIBU...... that is grand progress compared to earlier.....too soon to tell lol im trying to restore titanium backup
