NEED HELP GETTING FROM WHERE IM AT (ICS LEAK) TO STOCK AND 246 OFFICIAL ICS UPDATE!
Posted 02 December 2012 - 02:49 PM
The files i have downloaded:
Well i downloaded everything off of obsidians page. And i also backed up every file from my internal and my sd onto a computer.
My questions are...
1. After i get back to 5.9 following this step by step instruction how do i update to 6.7.
2. Now do i just regularly download the official ics (im also wondering if this is what you guys are reffering to the 246 ics).
3. Then how do i install safestrap and flash new roms
4. What are the best roms out there for me to check out. Ive been running rag3 for several months now and i also heard that eclipse ics and icaris hd are 2 good ones. Do you guys recommend these and what else is pretty good.
5. Thank you in advance for your help.
Posted 02 December 2012 - 03:08 PM
Maybe a Bionic user would be best for info, mine's a razr.
Posted 02 December 2012 - 03:15 PM
If your phone is working try finding hashcode on twitter. His blog hash of codes is listed at the top. Read about using safestrap 3, it is a great tool! With that you can try different roms our great devs have created.
yes but how do i start this whole process. i need to get from ics leak to stock and then i intend to upgrade via verizon to get to the official 246 ics. but i need step by step instructions since ive never done this b4
Posted 02 December 2012 - 05:26 PM
I believe Obsidian has everything there. The original firmware in a zip file to get you back to stock in stock recovery. Then the over the air should update you from there to most current. Like I said I'm a razr guy, but the principles are the same.
Are you on the 5.9.905 version now?
Posted 02 December 2012 - 05:44 PM
Sent from my DROID BIONIC using Xparent ICS Tapatalk 2
- hectorlumbago likes this
Posted 02 December 2012 - 06:07 PM
Matt, do you have a tool for the bionic?
ya i already downloaded all obsidians files i need. i just need someone to give me a step by step instructions so i dont end up bricking my phone.
Posted 02 December 2012 - 08:56 PM
This will erase everything but sd card and put it back to stock
Root with RAZR edge
