CM10 UNOFFICIAL (BETA) for Droid Razr HD (XT926) - Consumer and Developer Edition
11 replies to this topic
#1 dhacker29
dhacker29
    CM Master
  • 49 posts
  • Twitter:dhacker29
  • Google+:davidhackerdvm@gmail.com
Posted 04 December 2012 - 08:15 AM
Well I have been working since release pretty much on getting this to a semi functional state....So here it is CM10 (4.1.2) for the Droid Razr HD. This will work on both the retail consumer edition with SafeStrap3 and on the developer edition with CWM or TWRP recovery.
Thanks as always to:
Hashcode for always answering my questions
DroidTh3ory for getting me into this
Epinter for helping me get the ball rolling and fixing wifi and other things
Google for the source and awesome android
CM for all the mods and code fixes
OK first things first:
SafeStrap Version 3 for Consumer edition can be found here:
Follow the install and use instructions here:
Developer Edition:
CWM Recovery:
TWRP Recovery:
Working features:
Data: Should come up in 4G now
Voice Calls: Both speaker phone and handset speaker now
SMS/MMS: You may get random texts from VZWNMN Google for instructions to disable this
WIFI: Working in SafeStrap too thanks to some init*rc magic
Wifi Hotspot: Working
Bluetooth: Appears to work fine tested with headset for calls
What doesn't work (that I know of):
Wifi Direct, NFC, Camera
Download link:
GAPPS:
All source modifications can be found at:
As always enjoy and have fun!
  • Thach, lownslow200sx, andlaw and 1 other like this
#2 NattyBee
NattyBee
  • 647 posts
Posted 04 December 2012 - 08:56 AM
Thanks buddy! This is definitely very awesome!
#3 STiK
STiK
    STiK in the Mud
  • 304 posts
  • LocationEverett, WA
Posted 04 December 2012 - 09:28 AM
This supposed to work with the Moto ICS or Moto JB build?
#4 dhacker29
dhacker29
    CM Master
  • 49 posts
  • Twitter:dhacker29
Posted 04 December 2012 - 09:56 AM
It will work with either
  • STiK likes this
#5 STiK
STiK
    STiK in the Mud
  • 304 posts
Posted 04 December 2012 - 09:58 AM
TY Sir
#6 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 04 December 2012 - 12:34 PM
Thanks for sharing Dave! You da man, I don't care what hash says about you :P
#7 STiK
STiK
    STiK in the Mud
  • 304 posts
Posted 04 December 2012 - 07:16 PM
I'm sad.. This no workie with my Aussie Radio and T-Mobile :(
Great work on this btw DHacker.. Keep up the good work :)
#8 xcodybx
xcodybx
  • 48 posts
Posted 05 December 2012 - 05:55 AM
Each time I install and flash, I bootloop. I have no idea why..... So I guess this post is kind of pointless. lol.
IT'S JUST DRIVING ME CRAZY!
will keep trying.
#9 NattyBee
NattyBee
  • 647 posts
Posted 05 December 2012 - 07:09 AM
will keep trying.
Hmm...I haven't had a chance to flash yet, but I assume you are using the Razr HD or Maxx HD and you activated rom-slotX and did all the wiping stuff right? (factory data reset, wipe cache, wipe dalvik, format system) and then you installed first the rom & then the gapps?
I'm not trying to sound sarcastic, just making sure you've got that procedure down, since it's not posted in the OP, lol ;)
That's all I can think of offhand, as I'm no dev, and therefore have no idea what would cause the boot loop...but hopefully we'll get you up & running soon
Sent from my DROID RAZR M using Tapatalk 2
#10 xcodybx
xcodybx
  • 48 posts
Posted 05 December 2012 - 07:47 AM
I know you're not sounding sarcastic.... lol. I've installed roms for a while, and I have NO idea what I'm doing. Would placing it in the wrong place have something to do with it?
#11 coolestmage
coolestmage
  • 5 posts
Posted 05 December 2012 - 06:22 PM
This will work with ICS installed in the stock slot? I tried and I'm stuck on the cyanogenmod boot logo. It has been going for about 15 minutes now.
#12 STiK
STiK
    STiK in the Mud
  • 304 posts
Posted 06 December 2012 - 09:48 AM
For anyone who happens to be running their HD on t-mobile or AT&T with the Aussie radio via the method on
the radio will crash while running this. To get this to work with the above setup I edited my /system/build.prop to get this working with GSM. I don't know if you *HAVE* to make all 3 but this is what I did.
ro.mot.phonemode.vzw4gphone=1 change 1 to 0
telephony.lteOnCdmaDevice=1 change 1 to 0
ro.telephony.default_network=10 change 10 to 3
Seems to be working well for me so far.
This is in no way supported by Hashcode or DHacker at this point so please don't go filing bug reports to them while running this setup. They have enough BS to deal with without adding stuff like this to their plate :P
