I am running an xt926 on KitKat 4.4.2 V183.46.10. Recently, I rooted with towelroot and used the console command version of motopocalypse to unlock. All went well and I saw no errors. In fastboot it states code 3 and that I am indeed unlocked.
Directly following this, I downloaded the CWM apk and installed it, then, after renaming the default recovery recovery files via ES file explorer, flashed the vanquisher edition of CWM recovery. Upon reboot into recovery, I get the motorola (Dual core technology) spash as if I were booting up normally, but it persists for minutes. Eventually it reboots and the phone boots into the os. I have tried flashing TWRP, as well as the stock recovery but it behaves the same way. Also, I have tried flasing through the CWM app. All of these methods state that they are successful but the result is the same: a nonexistent recovery.
It should be noted that I have all of the appropriate drivers, including motorola's and adb, I have a proper root with updated SuperSU binaries, and have accepted the PC and am considered authorized, as shown by adb. I am also using the OEM usb adapter. Another item worthy of mention is that I have never received the telltale "bootloader unlocked" warning splash screen on bootup. I can only confirm that it is unlocked through fastboot mode, which works perfectly. I don't know if this is significant.
I am at my wit's end with this one. Can anyone here please shed light on this for me? I am afraid to take any further steps until I have a functional recovery. Any help is greatly appreciated.
