Posted 09 December 2012 - 06:42 PM
Posted 09 December 2012 - 06:46 PM
Sent from Razr Maxx running Full Throttle Killer Bean
- reese likes this
#3 Guest_HOFFA_*
Posted 09 December 2012 - 09:30 PM
Posted 09 December 2012 - 09:34 PM
Also this may help. Will only wipe internal SD I believe.Sorry to hear this. You did not install a tracker on ur device? Your sim card is the Issue. Call ur carrier. ASAP
Posted 10 December 2012 - 03:08 AM
Posted 10 December 2012 - 03:52 AM
i thought lookout had an app called plan b. you might can give that a shot.
Lookout can track the phone... lock it...make it scream or wipe all data remotely. The carrier should be able to track also, assuming it's being used with the original unaltered sim. So yeah I'd try to install it via google play on a pc and see.
Edit: forget the remote install... you need to accept the terms of service first and set it up...........
Posted 10 December 2012 - 06:29 PM
Yeah I was thinking you needed device admin and/or root permissions to do that... I use Cerberus and I have to set it up every ROMLookout can track the phone... lock it...make it scream or wipe all data remotely. The carrier should be able to track also, assuming it's being used with the original unaltered sim. So yeah I'd try to install it via google play on a pc and see.
Edit: you can agree to TOS on google play store, it's the setup where you run into trouble.
Posted 11 December 2012 - 05:40 PM
