NTFS, EXT4, exFAT and sdcard-ext?
Posted 10 December 2012 - 10:19 AM
Posted 10 December 2012 - 10:56 AM
Posted 10 December 2012 - 01:25 PM
sent from my spare phone tapadriving........
Posted 10 December 2012 - 02:17 PM
The process is goes like this. I insert the card. The Motorola auto-mount software recognizes that a card has been inserted, but it does not recognize the format. It displays a notification that says the card is either blank of has an unsupported format. Then Paragon recognizes the card and mounts it to the directory I indicate in the apps settings. The Motorola notification remains and I can not get rid of it.
My current avenue of thought is perhaps there is an apk in the Motorola roms that specifically handles the mounting and indexing on the internal and external storage. Perhaps I can freeze this and just use a 3rd party app to handle mounting. I am hoping that a developer might have some knowledge of any of the Motorola apks that may handle this.
Also I have discovered that although the card is mounted successfully, when using mass storage, mtp, or ptp for the pc connection, I can not access the card.
Posted 10 December 2012 - 02:27 PM
I also used the Paragon product on my Toshiba Thrive and it worked fine with ICS. However, it quit working when we started using custom CM10 ROMS on the Thrive and I had to use a different app to access my hard drive properly. I do want to emphasize that I have never tried it with an SDcard on either of my devices.
Good luck and let me know if it still works with the old ROM you were using.
Posted 10 December 2012 - 02:42 PM
Posted 10 December 2012 - 02:58 PM
Posted 10 December 2012 - 03:58 PM
Posted 10 December 2012 - 06:23 PM
Posted 11 December 2012 - 07:00 PM
Posted 12 December 2012 - 01:21 AM
Posted 12 December 2012 - 04:36 AM
