Max SD Card Class?
7 replies to this topic
#1 Guest_Xplorer4x4_*
Guest_Xplorer4x4_*
Posted 15 December 2012 - 10:13 AM
I have a Droid 2 Global and it never properly supported my Class 8(?) sd card. In fact Class 4 was the max it would handle if memory serves me right. So has any one managed to get Class 8 or higher working properly on the Razr HD?
#2 priddyma
priddyma
  • 114 posts
  • LocationDeKalb, IL
  • Current Device(s):HTC One XL, Motorola DROID RAZR
Posted 15 December 2012 - 03:00 PM
I have a class 10 SDXC 64GB in my RAZR. Should work in an HD as well.
You can generally use any class SD card in any device. It will depend on how fast the device can read/write to the card if it does not support speeds as high as a class 8/10.
DROID RAZR XT912 Batakang JB | Samsung Galaxy SIII Pebble Blue - On the way!
#3 Rycix
Rycix
    Bouncing Ball Of Energy / Android Rescue Squad
  • 107 posts
  • LocationNew England, USA
  • Current Device(s):XT912
Posted 16 December 2012 - 04:10 PM
Ditto. I have had no issues over here.
Droid Razr XT912, cooling down with ICS on 6.16.211
#4 Guest_Xplorer4x4_*
Guest_Xplorer4x4_*
Posted 16 December 2012 - 04:24 PM
It will depend on how fast the device can read/write to the card.
I think it is a little bit more then simple read/write processing ability because on my D2G, it would constantly make the SD card appear as R/O, when it was in fact R/W. Actually that was my Class 6 or 8 card. I tried a class 10, I believe, it was causing the phone to randomly reboot all the time.
Regardles, of the root cause, that's in the past. Since the Razr HD Maxx was on sale, I was able to pick it up today instead of the plain Razr HD, so I am hopping I can find my old SD card now. It got lost in the shuffle with the move a few months back.
#5 snowman
snowman
  • 111 posts
  • LocationSparta, Tn.
Posted 25 February 2013 - 07:03 PM
class 10 good for me I just want to be able to write that 1080 video fast
Do it now you may not be able to later
#6 Moonrakerone
Moonrakerone
  • 63 posts
  • LocationBoulder, CO.
  • Current Device(s):Droid Razr HD Maxx
Posted 26 February 2013 - 11:34 PM
Everything I have seen says that 64gbs won't work, that 32 is the most. You have it working consistently?
#7 Martin028
Martin028
  • 19 posts
  • Current Device(s):xt926
Posted 02 March 2013 - 02:33 PM
32gb class 10 works flawlessly on the hd over here
#8 dru21281
dru21281
  • 103 posts
  • Google+:dru21281
  • LocationNY
  • Current Device(s):Razr HD, Droid X, Razr, HTC Rezound
Posted 19 March 2013 - 01:14 PM
I have been using a 64gb class 10 for 3 or 4 months now on the HD and never had any problems... FYI
