Almost always my text icon shows I have 1 message although I have read them all or have completely deleted them all. It just randomly shows up and goes away. Does anyone know how to correct this issue?
Help with Texting App
DizzyFox
, Dec 16 2012 04:08 PM
3 replies to this topic
Posted 16 December 2012 - 04:08 PM
- DizzyFox likes this
Posted 16 December 2012 - 04:41 PM
Go into settings from your stock messaging app and disable notifications. Sounds like you didn't do that when you downloaded the messaging app you wanted.
Posted 16 December 2012 - 05:40 PM
Thanks for the reply. I did that already. It seems it does it with or without the notification checked or not. I am just using the stock messaging app. Its nothing I can't live with just love to figure out what's causing this quirk I may have to freeze this app with titanium and find another off the play store.
Posted 17 December 2012 - 01:48 PM
Well you could always try a factory reset if you don't mind reloading your contacts and Apps.
