[Theme] Razr's Edge For Razrx 1.2
#81
Posted 22 February 2012 - 12:33 PM
#82
Posted 23 February 2012 - 12:21 AM
#83
Posted 23 February 2012 - 12:23 AM
#84
Posted 23 February 2012 - 12:25 AM
#85
Posted 23 February 2012 - 12:26 AM
#86
Posted 23 February 2012 - 12:54 AM
I can probably do one. check out a purple theme I did for the X, let me know what parts of it you would like if any.any hopes of a black and purple theme for the razrx?
#87
Posted 23 February 2012 - 03:07 AM
#88
Posted 23 February 2012 - 10:08 AM
Ok, i can do a full port of violetvixen or create a violet edge theme based on it.man thats actually pretty sweet just the way it is... the blue razr edge is awesome... maybe a violetvixen theme for the razrx? let me know man...
Whatcha think?
#89
Posted 23 February 2012 - 10:10 AM
#90
Posted 23 February 2012 - 02:20 PM
#91
Posted 23 February 2012 - 03:17 PM
Well the most you have to do is swap images. The only xml edits would be for pulldown text and clock color but not necessary, should be fine without it. Just extract the new apk and the themed one, swap images and zip updated apk back up.hey wulf you wanna give me a short tutorial on updating the orange razrx theme? If you can point me down the right road I can do it myself instead of just requesting. Let me know man. Never learned how to theme or code so I guess I'll start with themeing then move on to full out coding - I figure themeing will help me learn my way around the framework.
Since most of the work is already done it usually takes me about 2-4 hours to update a theme, give or take 1/2 hour. Most time consuming part is creating it, lol.
Give it a shot, if you like i can update the theme for you. Just let me know.
#92
Posted 24 February 2012 - 10:20 AM
#93
Posted 24 February 2012 - 10:31 AM
In the process of doing just thatid just say to keep the razrx the same but see if you can change the colors over to purple like the red and blue one are...
#94
Posted 24 February 2012 - 01:22 PM
#95
Posted 24 February 2012 - 02:44 PM
Hmm, not sure. Maybe reflash RazrX 1.2 no data wipes, cache only is ok and try again. If it does work reflash theme and see if it still works.if i can make one tiny suggestion? any clue how to get the bluetooth to work on razrx 1.2... i came up with an error when i tried to use it...
#96
Posted 05 May 2012 - 09:42 AM
#97
Posted 05 May 2012 - 10:16 AM
With razor bootstrap first press bootstrap recovery then grant it permission then it should say success. Then press reboot recovery and it should take you to clockwork recovery.This might sound like a dumb question but I just rooted my phone the other day and have tried flashing the rom using rom manager and toolbox neither one working. I tried downloading a razr bootstrapper someone made but it seemed to just give me 2 options bootstrap recovery and reboot recovery no option to go to sd card. Also when you say Make sure you on RazrX 1.2 ,173 based rom is that my phone version or what? Hopefully you can give me a pretty simple descriptive way on how to do this with the right tools I need maybe links to those. Sorry for the long post.
To flash this theme you have to be on razrx rom , thread found here
[Rom]-Razrx-V1.2--[2/13/12] . Flash razrx first reboot then use razor bootstrap to go back to recovery then flash theme
#98
Posted 05 May 2012 - 01:08 PM
#99
Posted 05 May 2012 - 01:26 PM
Did you install razrx 1.2? If you did then you flashed theme download this and flash in clockwork then reboot, you should have settings again. Its a revert to RazrX stock zip. aftter you flash the revert zip you can go back to clockwork and reflash theme and settings should be there. let me know how it goesOk I have a problem I figured out how to download the roms but for some reason it wouldn't let me go to settings so when I booted up razr bootstrapper I clicked clear all data and I didn't know it would delete literally everything like my contacts now I can't go to settings to even do anything I'm stuck with everything lost what can I do to restore phone to factory settings.
#100
Posted 08 May 2012 - 04:39 PM
