External SD Card No Longer Recognized After Unmounting - Permissions Screwed?
#1 Guest_Xplorer4x4_*
Posted 16 December 2012 - 07:49 PM
Posted 16 December 2012 - 08:15 PM
#3 Guest_Xplorer4x4_*
Posted 16 December 2012 - 08:19 PM
Sent from my DROID RAZR HD
Posted 16 December 2012 - 08:39 PM
Edit.... Never mind... Didnt read your last line lol.....
sent from my spare phone tapadriving........
Posted 16 December 2012 - 08:45 PM
#6 Guest_Xplorer4x4_*
Posted 17 December 2012 - 12:43 PM
I forgot about that. I tried it but that did not fix it. It realizes a USB connections is made because it says USB debugging is on and it lets me choose media device and camera. but not the third option that enabled the sd card to be recognized. Can you check permissions on a similar device(one with an internal sd card and a external sd card) and report back what you have. I am not 100% sure it is permission related BUT it seems like the likely culprit because the card works fine in in a cheap pos usb card reader from ebay, and it worked fine in the HD before unmounting. I have tried to remove and insert it and reformat it, and every combination of such. No luck.Do you have safestrap installed?.... If you think it may be a permissions error there is an option in safestrap to fix permissions.... Maybe that will help
#7 Guest_Xplorer4x4_*
Posted 21 December 2012 - 11:38 PM
Posted 22 December 2012 - 12:15 AM
#9 Guest_Xplorer4x4_*
Posted 22 December 2012 - 12:18 AM
Posted 22 December 2012 - 01:45 AM
Im glad it is working for you now
#11 Guest_Xplorer4x4_*
Posted 23 December 2012 - 08:18 AM
Posted 03 January 2013 - 07:35 AM
Ross
Posted 15 January 2013 - 10:36 PM
