Force Reboot?
4 replies to this topic
#1 Guest_Xplorer4x4_*
Guest_Xplorer4x4_*
Posted 17 December 2012 - 09:35 AM
On my D2G if the phone froze up, I could hit ALT , Shift, Delete at the same time to reboot. on a Kindle fire, you can hold the power button for 10(?) seconds to force a shut down. Is there some similar method for the Razr HD?
#2 b_wat
b_wat
  • 79 posts
  • Google+:bwatkins232@gmail.com
  • LocationKnoxville,Tn
Posted 17 December 2012 - 11:05 AM
volume down and power
#3 Guest_Xplorer4x4_*
Guest_Xplorer4x4_*
Posted 17 December 2012 - 12:44 PM
In Batakang 1.0 that produces a screen shot, not a reboot. I tried every possible combo of hardware keys on the side, with no luck.
#4 jimboslice
jimboslice
  • 315 posts
  • LocationBeaverton, Oregon
Posted 17 December 2012 - 01:50 PM
Hold all three buttons down for 5-10 seconds. That will force a reboot.
#5 Guest_Xplorer4x4_*
Guest_Xplorer4x4_*
Posted 17 December 2012 - 01:51 PM
Exactly what I needed, tested and working! thanks!
