DroidRazr.com blocked
Posted 19 December 2012 - 03:31 AM
Your connection to this server has been blocked in this server's firewall.
You need to contact the server owner for further information.
Your blocked IP address is xx.xxx.xxx.xx
This server's hostname is
(I blanked out my IP address for obvious reasons.) Now none of my 8 home PCs can access droidrzr.com. Who can remove this block for me? Thanks.
Posted 19 December 2012 - 05:06 AM
#3 Guest_DirtyDroidX_*
Posted 19 December 2012 - 05:07 AM
Posted 19 December 2012 - 05:12 AM
Can you PM me the IP so I can assist and work with an admin on this issue.
I just PM'd DD my IP address. Thanks for your help.
Posted 19 December 2012 - 05:51 AM
Posted 19 December 2012 - 10:56 AM
#7 Guest_DirtyDroidX_*
Posted 19 December 2012 - 11:26 AM
Posted 20 December 2012 - 03:17 AM
If it can't be fixed online then I will haveto submit an ticket with our server.
As of this morning, my IP is still being blocked. Thanks.
Posted 20 December 2012 - 05:06 AM
you can force yourself a new IP by unplugging your modem, (write down your mac address on router) change the Mac Address on your router, then unplug the router plug in the modem wait about 5 minutes, plug in router, and it should force an IP change from your provider..
Posted 20 December 2012 - 05:13 AM
quangtran1, here is also an easy fix if you know how to do it,
Sure, no problem. In fact, I've done that: turned off the modem, waited a few hours while I went to town, turned it back on. And the dang thing still gave me the same IP because the ISP set the dhcp lease time to be 7 days. That's fine, I can force an IP renewal through other means at my disposal. The only problem I'm afraid of is that down the road it's probable that I will get re-assigned this same, problematic IP. That's ok, I'll deal with it. Thanks.
Posted 20 December 2012 - 05:20 AM
- quangtran1 likes this
Posted 20 December 2012 - 05:24 AM
No I didn't mean it that way, as Admins are working on that specific IP, my main goal is to get you up and running if it means changing the IP for now, as far as you ever getting that IP address again, would be like me winning the lotto, most likely its not ever going to happen lol.. The problem will not be ignored by Admins trust me on that.
Don't worry, I appreciate this forum and its admins.
- satman80 likes this
Posted 20 December 2012 - 05:40 AM
I know, we all do, they got skills either way let me know how you make out, if all is well, once the IP changes. Then maybe after 10 days we can put your Mac Address back in order.
