Input requested for laptop/tablet replacement (Surface Pro?)
ZKK007
, Dec 19 2012 11:10 AM
5 replies to this topic
Posted 19 December 2012 - 11:10 AM
Hi all,
I currently have a desktop, laptop and iPad 1. The desktop is my primary computer; however, I am looking into replacing my laptop/iPad. I would prefer to be able to run programs such as Photoshop and also android related progams such as apk-tool etc. I would love to do theming on the go. 3G/4G is not too important as I can use my phone as a hotspot if I'm out of wifi range.
I want to know what you all think about the current ultrabooks and tablets that are out. Please give some reasoning too
I am looking into getting the Surface Pro when it comes out as I have read it will have full Windows 8 which means I should be able use Photoshop on it. Since it has a USB input, I can also have my keyboard and mouse when using it. Yes, the price is high considering it has a 64GB or 128GB harddrive, but it does have a SD slot which can expand storage.
Is there anything else out there that you would recommend instead of the Surface Pro? If you were looking for a laptop/tablet replacement, what would you get?
I appreciate your input!
Posted 19 December 2012 - 12:40 PM
I like Asus in laptop and tablet
Posted 19 December 2012 - 01:03 PM
The asus Eee Slate B121 is a great option.
Posted 19 December 2012 - 03:20 PM
Thanks guys. I wasn't too aware of the Asus tablets, especially the B121. I will research more into it and see how it will compare with the Surface Pro.
Posted 19 December 2012 - 03:24 PM
Asus always seems to run good for me. Not sure of others thoughts about them. Hopefully you find something that fits you well.
Posted 19 December 2012 - 04:59 PM
Asus all the way.... .... i think the only thing i have that is NOT asus is my razr.....
sent from my DROID RAZR tapadriving ...
