Phone won't turn on after installing safestrap
Posted 21 December 2012 - 09:23 PM
Posted 21 December 2012 - 09:25 PM
- RzrMike likes this
Posted 22 December 2012 - 09:04 AM
Posted 23 December 2012 - 03:46 PM
I have had that happen to me... specially when phone dies. if you are plugged in, it wont want to come on, just unplug from wall turn on let it boot to at least the bootanimation than plug back in to the wall. if completely dead, than plug in let sit for about 20 mins or in many cases until the LED not flashing, than do same thing :unplug boot up and plug back in.
It wasn't dead before (different thing), but it is completely dead (battery) now and NOT turning on, no LED. I'm on CM10 and worried the battery isn't charging. I really miss battery pull....
- drummer261982 likes this
Posted 23 December 2012 - 04:32 PM
i would say just let it sit for a while... charging that is... and try again... but remember to umplug... and be patient with it... it happens to me all the time...It wasn't dead before (different thing), but it is completely dead (battery) now and NOT turning on, no LED. I'm on CM10 and worried the battery isn't charging. I really miss battery pull....
- hillmom likes this
Posted 23 December 2012 - 04:46 PM
Thanks. It has been "charging" for over a half hour and still nothing. I fear I need a factory cable...
Posted 23 December 2012 - 05:11 PM
From the RAZR M
Posted 23 December 2012 - 05:43 PM
glad to hear.... like I said be patient with it ...Held volume buttons and power for a min, and and it booted. It was even at 91% when it turned back on. Though I think I will get my hands on a "factory cable" for the eventuality that I do need one some day.
From the RAZR M
Posted 17 February 2013 - 01:43 PM
Posted 17 February 2013 - 01:44 PM
battery pull was the s***It wasn't dead before (different thing), but it is completely dead (battery) now and NOT turning on, no LED. I'm on CM10 and worried the battery isn't charging. I really miss battery pull....
Posted 26 February 2013 - 07:44 PM
Posted 27 February 2013 - 11:06 PM
if phone dont boot or stuck in bootloops after installing safestrap wipe cache and dalvik in recoveryI have the same problems when my phone is charging and trying to use ss I always just 3 button reset it works every time
Posted 28 February 2013 - 06:13 PM
sig made by
Rinkle McBally
