[Wip] Motorola P893 Portable Charger Review
6 replies to this topic
#1 benefit14snake
benefit14snake
  • 232 posts
Posted 29 January 2012 - 04:21 PM
This is a work in progress review of this item. I do not work for Verizon or Motorola. I also was not given this for the purpose of reviewing. I bought it with my own money, if you have any problems with the device I am not tech support. If you have any questions I will do my best to answer them.
For tonight I will start with pictures as it is currently charging. I will update this with charging stats later in the week when I have time.
This thing is pretty small, not quite as thin as my RAZR but definitely shorter and not as wide. It has an all plastic body with two small screws in the back. There is a full size usb that allows you to connect a power/data cable from other vendors. It also has a motorola cable that is about 6 inches in length that snaps into the body, as well as a charging port that the supplied cable plugs into to charge it. The charging cable is approximately 6 feet in length with the standard Motorola logo on the front. It has an internal battery of 1820/1860 mAh.
It has an input of 5v @ 950 mAh.
It has an output of 5v @ 500 mAh.
More to come later. Stay tuned.
Sent from my Transformer Prime TF201 using Tapatalk
#2 benefit14snake
benefit14snake
  • 232 posts
Reserved.
#3 benefit14snake
benefit14snake
  • 232 posts
Posted 29 January 2012 - 04:22 PM
Also reserved.
#4 Droid2drummer
Droid2drummer
  • 324 posts
  • Twitter:@imanotemaker
  • Google+:robertclarkga@gmail.com
  • LocationWarner Robins GA
Posted 29 January 2012 - 05:10 PM
Have you seen the battery equipped case? Keeping the thinness as it uses a super thin battery. Dont remember where I saw it but they exist. And they are getting better..
You've been tapped by the Drummer...
#5 CTRaider
CTRaider
  • 5 posts
  • Google+:ctraider
  • LocationBackwoods, CT
Posted 31 January 2012 - 12:43 PM
I use a Tekkeon TekCharge MP1800 (4,000 mAh). Same price, more options to power other items. Got mine at Amazon.
#6 mopar57
mopar57
    Developer/MOD
  • 375 posts
Posted 31 January 2012 - 01:10 PM
Snake...just a heads up, It uses the same battery from the OG/D2/d2g/pro etc.
And if you have the extended battery BP7x and a razr blade (not the phone :) ) then scrape a little plastic off the inside of the case and the extended battery can be used inside the case.
Just a thought on how to put the old batteries to work!
Got an idea for a theme?
PM me!
I like mail! :D
#7 benefit14snake
benefit14snake
  • 232 posts
Posted 31 January 2012 - 01:19 PM
And if you have the extended battery BP7x and a razr blade (not the phone ) then scrape a little plastic off the inside of the case and the extended battery can be used inside the case.
Wow thats awesome stuff. Wonder if my bionic extended battery would work?
