Beats Audio
#1 Guest_DirtyDroidX_*
Posted 24 December 2012 - 08:56 PM
You can be the judge on if it boosts your quality or not. I have tested it out on several different audio sources, an can say I notice a big improvement.
Yes you need to be rooted !!!
Yes it works on stock and deodex systems.
Drop your opinions below!
DirtyDroidX
Tapped from my XT926, XT913 or SCH-i535.
Posted 25 December 2012 - 01:23 PM
Posted 27 December 2012 - 12:40 AM
Posted 27 December 2012 - 08:25 PM
#6 Guest_DirtyDroidX_*
Posted 28 December 2012 - 04:21 PM
Does anybody know where I can get the stock jb drivers/files that this replaces or overwrites I hit the install button without backing up and now everything sounds more quiet so I would like to find a way to put the stock stuff back without having to flash back and do the whole root and setting things back up any help would be appreciated
Yeah I found the post on xda but did not bookmark it. I will look and post a link later on. If anyone has a link please post.
Posted 29 December 2012 - 03:58 AM
I ran across this yesterday but have not tried it yet;
Posted 29 December 2012 - 09:26 PM
install using the Aroma full version... use the universal plugin when prompted, I personally am using it with just Awesome Beats (dsp manager)... but depends on what version of OS u are on... try noxoide... I found it too hectic to go that route..
Also, where it gives you the build.prop additions... those will NOT be added automatically, I have checked,... once the installation is done... go and add those lines to the buildprop.... excluding the "resampling" part
Posted 30 December 2012 - 04:18 AM
Posted 30 December 2012 - 07:33 PM
