Spotify Backup Solution?
6 replies to this topic
#1 Alex.Abraham
Alex.Abraham
  • 477 posts
  • Twitter:aabraham123456
  • LocationNew Jersey
Posted 25 December 2012 - 01:13 PM
Anyone who uses spotify knows that whenever you flash a ROM you wipe all the downloaded music off the phone. Anyone figure out a way to back up the cache to the external SD so I don't have to keep downloading songs every time?
#2 Alex.Abraham
Alex.Abraham
  • 477 posts
Posted 31 December 2012 - 08:28 AM
Anyone?
#3 scottpole
scottpole
  • 102 posts
Posted 31 December 2012 - 09:13 AM
Try using an app called Gameloft to SD. Every time you factory reset you'll just need to download the app again and mount.
#4 L4M3N7
L4M3N7
  • 25 posts
  • Twitter:L4M3N7
  • LocationPittsburgh, PA
  • Current Device(s):RAZR Maxx
Posted 01 January 2013 - 08:25 AM
I cancelled my premium recently. I know it ate up a ton of my space though. I think you can actually move the files to the SD card with the tools in Settings, then move back after flashing. It would probably be the best shot at working at all. Option 2 is to backup the folder manually and move it back manually. Sadly I forget where that folder actually is. I found mine by use a storage analyzing app. I'm probably reactivating it again really soon so if I can figure something out I'll toss it your way.
#5 Alex.Abraham
Alex.Abraham
  • 477 posts
Posted 01 January 2013 - 08:45 PM
Thanks! Spotify removes the external SD settings when they did a UI revamp but I will try Gameloft to SD :)
#6 L4M3N7
L4M3N7
  • 25 posts
  • Twitter:L4M3N7
Posted 02 January 2013 - 08:19 PM
I didn't think of this before but Titanium Backup Root can restore game saves and such. Did you try doing a backup and restore using that yet? Just updated my Wizzed Bean ROM and it saved me a massive headache.
#7 Alex.Abraham
Alex.Abraham
  • 477 posts
Posted 03 January 2013 - 09:16 PM
Ya titanium doesn't back it up for some reason :(
