Soft Keys
Posted 29 December 2012 - 08:11 PM
I'm coming from the Nexus and was hoping there was a way to change them. Before the ability to change them was built into the ROMs there were flashable zips to do the work for you. Is this possible with the Razr HD?
Posted 29 December 2012 - 08:16 PM
can use the same soft keys as from your nexus thats what i do take the ones i like and then replace them in the system.uiIs anyone working on any mods to change or add softkeys?
Posted 29 December 2012 - 08:27 PM
Posted 02 January 2013 - 02:59 AM
Posted 21 January 2013 - 08:34 PM
I can make any softkeys you want, Ziptheamer will not work on stock rom. Tell me what you are running and what kind of softkeys you want
I've just been changing out different images in the systemUI.apk and reflashing it. Softkeys included.
I'm kind of a Frankenstein themer meaning I change some images then swap them out to try and get what I want.
I haven't been able to switch out as many images as I want tho.
Is that something you could maybe help me with? I've always been hesitant to do anything with .9png's.
Posted 02 February 2013 - 07:18 PM
Posted 04 February 2013 - 06:17 PM
Edit: Found them
Posted 05 February 2013 - 04:10 AM
Posted 15 June 2013 - 06:51 PM
Any chance you could make me some for the JB Stock 4.1.2 rom? I just got the device, but the missing search and menu keys is KILLING me.
