phone stuck at boot! please help
Posted 01 January 2013 - 10:54 AM
as far as i know i can't use matt's utility because it's only for ICS right?
either way do you have any ideas on getting my phone back up and running?
Posted 01 January 2013 - 10:56 AM
Posted 01 January 2013 - 11:00 AM
Are you able to uninstall SS? If so, do that, then try to reflash. Root will probably be lost though.
how do i do that without booting?
Posted 01 January 2013 - 11:02 AM
Posted 01 January 2013 - 11:10 AM
Are you able to get into recovery? Is JB on your ext sd?
yes i can get into the newest SS and also have a JB .zip on my internal and external sd.
i've tried many times to wipe and re-flash the .zip file but it just doesn't boot right. i don't know what wrong with the newest SS?
Posted 01 January 2013 - 11:13 AM
Posted 01 January 2013 - 11:27 AM
Posted 01 January 2013 - 11:29 AM
Posted 01 January 2013 - 11:35 AM
Posted 01 January 2013 - 11:48 AM
