need safestrap help force closes right away
Posted 10 January 2013 - 07:33 AM
Posted 10 January 2013 - 08:27 AM
I'm rooted in jb ota. I installed safestrap but its not opening it force closes right away.its safestrap 3.12 right of of hash of codes website I have a hd maxx I doubt thats the problem .thanks alot guys
sk8, which version of SS were you on b4? Did you install it into the Stock, Non-safe side?
How did you u/g to JB, OTA or Matt's util & sideload?
Posted 10 January 2013 - 08:32 AM
Posted 10 January 2013 - 01:07 PM
Posted 10 January 2013 - 02:54 PM
Posted 16 January 2013 - 11:21 AM
is:/dev/block/platform/msm_sdcc.1/by-name/:
no such file or directory
3.12:0
so i looked to make sure file was installed it says it was so i tried to uninstall then reinstall still nothing
i was running cm10.1 on my last phone an really want to get back to it help me please
#7 Guest_Xplorer4x4_*
Posted 16 January 2013 - 11:49 PM
im cant get safestrap to boot up. i bricked my old razr and just got a new one rooted it used root checker to verifiy root. i have root when i installed safestrap 3.12 installed file tried to reboot an safestrap never came up to access into it. go to su logging and it say
3.12:0
You should probably start your own thread since you have a different problem not related to the op.
As for the original problem, I had the same problem. I simply downloaded the apk from the thread in the RAZR HD category(Dev section maybe?) again and it solved the problem. I am not sure if it is the same apk from hashcodes site as his site does not mention the RAZR HD anymore.
Sent from my DROID RAZR HD using Xparent ICS Tapatalk 2
