Dead Android Symbol
12 replies to this topic
#1 bbbjo
bbbjo
  • 6 posts
Posted 11 January 2013 - 05:37 AM
Hi,
Yesterday I installed safestrap 3 and was going to install the Wizzed Bean CN4 ROM. I was previously running cm10 aokp and followed the directions as they were stated. After I installed the ROM and tried to reboot I got the dead android symbol and the phone wouldn't boot up. I tried to go into recovery and it did the same thing. Now I am not sure what to do. I've searched on google for this symbol but not much about it regarding the Bionic. As Brian pointed out to me yesterday in the chat room I can get into stock recovery when I am at the dead android screen. I was able to do that but not sure what to flash there. Any help would be appreciated.
Thanks!
#2 B.E.McAllister
B.E.McAllister
    Paint by Number Master
  • 355 posts
  • LocationUT, PA
  • Current Device(s):Bionic
Posted 11 January 2013 - 05:40 AM
If your OK with losing any data on your internal system (won't affect the SD card) I would first try a factory reset from stock recovery.
#3 bbbjo
bbbjo
  • 6 posts
Posted 11 January 2013 - 06:14 AM
I'm ok with doing that but I did wipe format from stock recovery and it didn't help unless i'm going to the wrong place.
#4 VantenKiest
VantenKiest
    Guru of Insanity & Tech support
  • 668 posts
  • LocationPittsburgh PA baby
Posted 11 January 2013 - 06:25 AM
at dead android symbol press both volume buttons
:D
#5 DrunkulaTX
DrunkulaTX
  • 124 posts
  • Twitter:drunkulatx
  • LocationDenton, TX
  • Current Device(s):HTC Droid DNA
Posted 11 January 2013 - 08:36 AM
I had the same thing yesterday. Not sure why! I pulled the battery, reinserted it and it powered up fine. Go figure...
HTC Droid DNA
Droid RAZR XT912 (retired)
#6 bbbjo
bbbjo
  • 6 posts
Posted 11 January 2013 - 08:40 AM
yea i tried all that to no avail. i pressed both volume buttons at the dead android and all it says for options is reboot system now, apply update from external storage, wipe data/factory reset, wipe cache partition, and apply update from cache. i tried both wipe options and neither worked.
#7 B.E.McAllister
B.E.McAllister
  • 355 posts
  • LocationUT, PA
Posted 11 January 2013 - 09:22 AM
Sounds like it's time to fxz
#8 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 11 January 2013 - 01:06 PM
Did you try to flash CN4 over the stock ROM by chance? I would agree with ^ that it may be time to fxz.
#9 bbbjo
bbbjo
  • 6 posts
Posted 11 January 2013 - 03:44 PM
Yep I am fxz'ing right now. I had tried 905 earlier and it didn't work so I am installing 246 per SPJESTER's :)
**I can report that FXZ'ing to 246 worked!
Thanks everyone for their help!
#10 B.E.McAllister
B.E.McAllister
  • 355 posts
  • LocationUT, PA
Posted 11 January 2013 - 03:59 PM
Were you on .905 to begin with?
#11 bbbjo
bbbjo
  • 6 posts
Posted 11 January 2013 - 06:09 PM
Yes, I was on 905 to begin with.
#12 B.E.McAllister
B.E.McAllister
  • 355 posts
  • LocationUT, PA
Posted 12 January 2013 - 11:25 AM
That's why you bricked, trying to install a ICS ROM on gingerbread. Glad your backup and running
#13 bbbjo
bbbjo
  • 6 posts
Posted 13 January 2013 - 05:13 PM
Ooo, I didn't even realize that. The Bionic isn't my daily use phone and was thinking 905 was ICS. But yes I am glad I am up and running too.
Thanks!
