WORKAROUND for recovery error (Status 0):
1. Unzip your ROM and find
META-INF/com/google/android/update-binary file
2. Put this file in the UOT zip (overriding UOT's file)
However, that didn't help, I still got the Status 0 error when I tried again. I was wondering if any of you smart guys would be able to take the original UOT file and fix it for me, then let me know what you did. The rom I am using is Abysm v1.1, and I used the update-binary file from the v1.1 update file that I flashed when I updated from v1 to 1.1.
I would appreciate if anyone could help me, and even more appreciate an explanation of what was wrong, since that helps me learn more stuff. Here is a link to the original UOT Kitchen file I made, before I did anything to it:
