Auto update problem
Best Answer dlw , 17 April 2015 - 12:25 PM
All better now... Thanks, again.
Go to the full post
3 replies to this topic
#1 dlw
dlw
  • 96 posts
  • LocationAmboy, WA
  • Current Device(s):xt926
Posted 17 April 2015 - 12:03 AM
Inadvertently pressed install on the update screen.
Now during boot up, the boot system goes to TWRP and halts.
Is this the correct way to install the auto update?
Or, is TWRP being installed causing a problem?
#2 RikRong
RikRong
    Cap'n Slow
  • 2,116 posts
  • Twitter:@rlongjr80
  • Current Device(s):Moto X Pure 2015 / N7 2013 / RazrM
Posted 17 April 2015 - 02:34 AM
TWRP being installed is the issue. You'll need to restore to stock, then OTA, or just upgrade via FXZ.
  • johnthehillbilly likes this
R. Long: Nexus 5 on Carbon / Slimmed N7 2013 / RazrM stock KK
#3 johnthehillbilly
Posted 17 April 2015 - 04:58 AM
If you want the update..... "Install" it via house of moto (same method you used to "install" the .10 version so you could unlock :):)
  • RikRong likes this
#4 dlw
dlw
  • 96 posts
  • LocationAmboy, WA
Posted 17 April 2015 - 12:25 PM   Best Answer
  • johnthehillbilly, RikRong and zekemo like this
