Skype For Razr
Posted 01 February 2012 - 08:31 PM
Posted 01 February 2012 - 09:24 PM
Posted 01 February 2012 - 09:29 PM
Posted 01 February 2012 - 10:33 PM
i downloaded skype and it says that the device is not compatible. i can call but the video does not work. is there a fix for this?
I use Skype consistently and my video chat works for both cameras front and back
Posted 01 February 2012 - 10:56 PM
Posted 02 February 2012 - 09:03 AM
Posted 02 February 2012 - 09:05 AM
Posted 02 February 2012 - 09:10 AM
Posted 02 February 2012 - 09:13 AM
If you skype, please dont use a phone that contains anything that you dont want others to see. Skype's code is wrote by the same people that wrote kazaa, and the reason why it is free is because they use your phone/computer as a host/server for others to connect though (p2p). Even when its non-active its still being used as a host.
Wow, thanks for the heads up. Did not know that, but it would explain why having skype installed seems to keep my fiancee's wireless adapter active. I had tossed it up to faulty coding and moving too much data when syncing the contacts list.
Posted 07 February 2012 - 02:50 PM
Thanks for that warning. Any such issues with Tango? I've used Tango with my business partner, but his connection is only 3G while I'm on WiFi, so it's like I'm next door and he's on Alpha Centauri. Until he can afford a new router we just make regular calls and email.
