Droid Razr M Mass Storage configuration.
Posted 15 January 2013 - 08:22 AM
Thanks a lot in advance.
Posted 25 January 2013 - 06:21 AM
Sent from my XT907
Posted 12 April 2013 - 06:50 AM
Ian
Posted 12 April 2013 - 08:50 AM
It would be great!Ive been working on this downgrade masquerading as an upgrade. If I can get this sorted out Ill post here.
Ian
Good luck
Gene
Posted 09 May 2013 - 07:00 PM
Well, I did look into this for some time. Apparently Google/Android has seen fit to due away with mass storage at the root . Without writing a long dissertation here most of alleged reasons why turn out to be largely trite and SPURIOUS . Belive me when I say I could go on an extended tirade about this. Ultimately I personally think Google wants us using the cloud.
At any rate all I could find was work arounds.
After trying a great many things the best software I could find was Android Commander.
Its not the old plug and play but doesn't appear to have a lot of dependencies like the others. Although it says it requires root I don't know if its necessary just to mange SD card files.
Also you can try an app called FTP server. Its one of the few that appears to be able to access the SD card but it does require user input to do so.
Sorry, I wish I could have helped everyone.
Ian
