Motorola Upgrade/downgrade Links (Official/unofficial) 6.11.744-6.12.174
31 replies to this topic
#1 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 03 February 2012 - 05:22 PM
Upgrade from 6.11.744 to 6.11.748
MD5: 7265435d5e0db35dba4928d6003be682
Upgrade from 6.11.748 to 6.12.173
MD5: aa7fe6290c0d3a60253922bac413da02
Downgrade from 6.12.173 to 6.11.748
MD5: 7cadbe9436128d4285b48cf3ae0213cd
Upgrade from 6.12.173 to 6.12.174
DOWNLOAD REMOVED.... Not going to be official update!!! (If you cannot fastboot/RSD Lite you'd be stuck here.)
Flash these using the stock Motorola Recovery. (Power by holding up both volume buttons and the power button, and choose Recovery. When you see the triangle hit both volume buttons than Install update from .zip on the SD card).
Edited by mattlgroff, 09 February 2012 - 02:23 AM.
DOWNLOAD REMOVED.... Not going to be official update!!! 174
  • MrFrankRazr, mugsy77, CtrlAltDeath and 5 others like this
#2 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
  • Twitter:@MrFrankReyna
  • Google+:frankreyna
  • LocationSoCal, USA
Posted 03 February 2012 - 06:57 PM
Good stuff matt! Thanks!
#3 scott.fitz.fitzgerald
  • 52 posts
Posted 06 February 2012 - 02:00 PM
Hey Matt! Guess what?!? Updated to 174 (well 173 then 174 of course) and know what I found? The Bluetooth stereo issue that I had posted is apparently fixed! That's quite funny though because Motorola support said "that's not a known issue that we've heard of". Well apparently someone knew something if their update fixes it (or should I say impending update)! That will now allow me to return the new headphones and save $130. Sweet stuff. Thanks!
  • mattlgroff likes this
#4 drsuse
drsuse
  • 57 posts
  • LocationTexas
Posted 06 February 2012 - 10:58 PM
are these links good? i am on 748 and just tried updating to 173 and i got errors during recovery
Edit: NM I am a dumb rear end... I think I just need to read the post to go to 173 before 174.. sorry guys
#5 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 07 February 2012 - 12:18 AM
That's some good stuff there. Congrats!
#6 scott.fitz.fitzgerald
  • 52 posts
Posted 07 February 2012 - 06:30 AM
@drsuse - Yeah that would probably do it! Links should be fine. I pulled and flashed yesterday a few minutes before my previous post. Rooted or not should be fine but as the instructions said do make sure that you're on a stock rom if rooted. I was rooted but using a straight up stock rom as most of the roms that I've tested don't seem to be able to work with webtop on my lapdock.
#7 drsuse
drsuse
  • 57 posts
  • LocationTexas
Posted 07 February 2012 - 07:35 AM
i think the status 7 issue i was having was when i used uot kitchen i changed system files.. so technically its not stock.. yeah i was trying to rush through it.. my fault.. should stop and read the directions
thanks
#8 pm1066
pm1066
  • Validating
  • 140 posts
Posted 07 February 2012 - 04:03 PM
Still no way back from .174?
#9 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 07 February 2012 - 04:26 PM
You can fastboot back to 6.11.744 using my Full Utility
#10 pm1066
pm1066
  • Validating
  • 140 posts
Posted 08 February 2012 - 05:42 AM
Fantastic. I've already lost the love for .173 given some of the issues.
#11 drsuse
drsuse
  • 57 posts
  • LocationTexas
Posted 08 February 2012 - 08:53 AM
i a
i agree... this new update is awesome... i am staying at 173 and not going to 174. but i am rooted and my LTE never drops
just re read it LOL.. i mean i love this update.. its awesome. i dont have any issues guess im lucky, and i dont use alot
DAMN ADHD.... i didnt read it again..LOL sorry disregard
Edited by drsuse, 08 February 2012 - 09:04 AM.
#12 scott.fitz.fitzgerald
  • 52 posts
Posted 08 February 2012 - 09:01 AM
That's strange. I haven't had any problems that I can tell from 174. I did test and find that 173 app tray search does force close and it was resolved on 174. No LTE problems though.
#13 pm1066
pm1066
  • Validating
  • 140 posts
Posted 08 February 2012 - 10:34 AM
One problem I encountered with.174 was a fc with Smart Actions when trying to turn off cellular data.
Fixed it by reverting to the prior SA version.
#14 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 08 February 2012 - 02:24 PM
That's good to know. Thanks for noting this, I'll see if its around in other version
#15 KANYONKRITTER
KANYONKRITTER
  • 41 posts
Posted 08 February 2012 - 05:08 PM
oops posted in the wrong thread earlier.....I get this error when I attempt to update via update.zip
assert failed: file_getprop("/system/build.prop","ro.
:2.3.6/6.5.1-167_DHD-14_M2-5/111228:user/release-keys"
ll file_getprop("/system/build/.prop", "ro.build
.fingerprint") == "verizon/spyder_vzw/cdma_sypder:2.3.
6/6.5.1-167_DHD-14_M3-1/120125:user/release-keys"
(Status 7)
Installation aborted.
#16 KANYONKRITTER
KANYONKRITTER
  • 41 posts
Posted 08 February 2012 - 05:12 PM
and I am mo-tard I cant get your utility to work.....I am missing something I am sure. when i click on the .bat file a cmd prompt window opens and the last thing it says is "daemon started succesfully" and then it disappears. sorry but I am a noob and it seems like everytime i try something with thisphone I have trouble. My D2G was a dream compared to this thing.......its been a nightmare
#17 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 08 February 2012 - 05:32 PM
Try running it as admin. That will disappear then show up the main menu normally. As to your status problem.. make sure you are on the right system for the update and it fully downloaded
#18 KANYONKRITTER
KANYONKRITTER
  • 41 posts
Posted 08 February 2012 - 05:53 PM
And im running xp...not sure if that matters. At any rate i thank you for the quick response and all your hard work.
#19 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 08 February 2012 - 06:33 PM
Looking at the build.prop error it definitely is because you are not running the right package for your system. If it helps. the .zip are named for the system they are meant to be used ON. Not going TO.
#20 MonkeyMouth
MonkeyMouth
    Boot Logo Master
  • 148 posts
  • Google+:Adriano.Badilla@gmail.com
  • LocationLaveen, Arizona
  • Current Device(s):DROID ULTRA
Posted 08 February 2012 - 07:43 PM
I assume that this has to be installed from stock with all bloat intact. With root keeper. Or can I flash this over Abysm 1.1?
  • pm1066 likes this
Yet again. It isn't nessacary. But if you like my work or just want to be generous. Buy me a Monster. So I can stay up:P
