Ics And Rooting?
Posted 04 February 2012 - 10:16 PM
Posted 04 February 2012 - 10:19 PM
Posted 05 February 2012 - 03:58 AM
But you may want to protect your root before any updates.. I learned my lesson in the last ota update..
Sent from my Motorola Razr XT910
Posted 05 February 2012 - 10:12 AM
Protect root?? (plz advise)You won't need to do anything as long as you don't touch the bloatware.
Posted 05 February 2012 - 12:08 PM
Posted 05 February 2012 - 12:29 PM
Posted 06 February 2012 - 05:57 PM
What does protect root mean? You mean backup all my apps and stuff with Titanium?? And I know there's no official stock ICS I'm just wondering if I should wait and root it or just root it and wait for the update. I also plan to remove all the bloatware that isn't necessary like the stock browser, Vcast stuff, and the stock SMS and other little things. What should I do if I plan on removing the bloatware I don't want?
Before you flash any new updates, or before you download, and install an OTA update, and your rooter, you have to download OTA RootKeeper from the market place, and launch the app, and simply click on "Protect Root" and thats it, now you can install your OTA update, and once all is done installing, you simply launch the app again, and click "Restore Root", which will restore your root files, so you will be rooted again without having to go through the root process, or possibly not being able to root with a new update.
- buckeyestilidie likes this
