1% hack for JB deodexed rom
Posted 17 January 2013 - 06:46 PM
Posted 17 January 2013 - 07:11 PM
Anyone have a 1% flashable zip for the JB deodexed rom ???
It's out there as I know it has been implemented on the JB ROMs. If one of those guys could plop the services.jar and systemui.apk into a zip with an updates script you'll be in business. .
- wabmorgan likes this
Posted 17 January 2013 - 11:51 PM
here's the service.jar that you can install with root explorer make sure your ROM is 100% deoxed and make sure you have backup.....I'm running it on my phone works
- perfoliate and wabmorgan like this
Posted 18 January 2013 - 12:39 AM
so this will not work on the OTA jb?here's the service.jar that you can install with root explorer
Sent from my Droid Razr Maxx on 4.1.2 with Tapatalk2.
Posted 18 January 2013 - 11:06 AM
yeah it works.....I forgot to mention it's not a system ui.apk so it won't change your battery icon it just changes your battery increments youll notice it in the charging screen
Posted 18 January 2013 - 02:48 PM
But if it's the stock ota, how can it be deodexed?yes its for the jb ota like I said make sure your using a 100% deodexed ROM before replacing and make sure you have a backup
Sent from my Amazon Kindle Fire using Tapatalk HD
Posted 18 January 2013 - 05:01 PM
Sent from my Motorola Galaxy s3 using Tapatalk 2
Posted 18 January 2013 - 05:47 PM
Thanks for this!
Posted 18 January 2013 - 06:21 PM
you know there's stock ROMs that can be flashed?its for those kind of stock ROMs that are usually deodexd...sorry if I'm taking too long to reply I'm at work
Posted 18 January 2013 - 06:59 PM
Posted 18 January 2013 - 07:00 PM
That's OK.... as long as I get a 1% hack its fine. I am running the RAZR M circle widget.
Posted 18 January 2013 - 07:26 PM
Posted 18 January 2013 - 07:52 PM
Worked like a charm. :-) Thanks :-)
cool I'm glad it worked for you
Posted 19 January 2013 - 02:28 PM
Posted 19 January 2013 - 03:03 PM
One of two ways:How would you install this?
You can d/l it as is, use a root file explorer to find the one you have in system/framework & delete it or rename it.
Then find the one you just d/l'd & move it to system/framework & match permissions.
Or, you can check out the jellywiz thread where one of the devs has made a flashable zip.
Posted 19 January 2013 - 06:51 PM
- aaki_rocker likes this
Posted 20 January 2013 - 02:42 PM
Can this be used on the stock ota? Or do you need to be deodexed?Flashable zip link
Posted 20 January 2013 - 04:40 PM
deodexed
Posted 23 January 2013 - 08:04 AM
is there a version out there for the stock ota jb?deodexed
Posted 23 January 2013 - 09:06 AM
