Has anyone had success using the latest SS with the ability to flash the stock slot actually flashed any custom roms that work.
Pre SS using bootstrap that was all we could flash was stock.
My slot 1 Icarious HD rocks and would like to change the stock slot.
Tried it with kill rom and ended up with a broken stock slot. Was able to HOB out of it and it actually left my slot 1 intact after it was all said and done.
Any roms other than stock able to be flashed into the stock slot with ss3.11
kamisan
, Jan 22 2013 06:46 AM
6 replies to this topic
Posted 22 January 2013 - 06:46 AM
I don't dial 911
Posted 22 January 2013 - 10:54 AM
Out of curiosity, why do you want it in the stock slot? Roms function perfectly fine in safestrap's rom slots
Posted 22 January 2013 - 07:46 PM
i would like it to save space on my internal sd card since i never use stock rom anyways
Posted 22 January 2013 - 07:50 PM
You can flash ROMS to the stock slot just fine from what I've heard. I would just keep in mind that a messed up flash on the stock slot is a lot worse than one on a ROM Slot.
Posted 22 January 2013 - 07:55 PM
Reason for wanting it is merely space, tons of apps and if I had my icariushd on stock that would free a few hundred meg. right now I have a 2gb slot for it and not enough left over for another rom except for that pesky stock area.. already dorked the stock spot once,, would risk it again if I knew it would work, I thought some things might have to be changed on the scripting perhaps to reflect the location of storage etc.. didn't know.
I don't dial 911
Posted 22 January 2013 - 08:01 PM
JJNot sure if it's already changed (Hashcode said full ROMS was up next) but last I heard you could flash zips to stock but not ROMS yet.
Edit: or what jp said.
__________________sent from my bionic with dub_________________
Posted 25 January 2013 - 06:41 PM
Tried Icarious 1.7 on stock , said flashing, rebooted,, still stock,, but nothing messed up
I don't dial 911
