Stuck On 6.11. 748
7 replies to this topic
#1 racedog
racedog
Posted 09 February 2012 - 03:45 PM
I've had the Maxx for only two days. On day 1 I rooted the phone, installed razrbootsrap and made the mistake of removing a number of pieces of bloatware from the phone. Today I received the update. I was told in chat here to run the update. The update won't run because the bloat was removed. I was then told to run the eclipse rom but I can't do that because it requires 6.12.xxx. I seem to be stuck.
I noticed (I think here) that there is a zip of the bloatware. Is it possible to run that zip to re-install the bloatware? If so, how do I try to get the update again now that it has failed?
I'm really stuck here and sure could use some help. Oh yeah, I used doomlord to root, along with razrbootstrap I also installed the utility so that it always boots to cwm when power is turned back on.
R
#2 simon_lefisch
simon_lefisch
  • 265 posts
  • Current Device(s):Razr Maxx
Posted 09 February 2012 - 07:35 PM
If all else fails you can fastboot to stock then receive the updates.
#3 bullswife98
bullswife98
  • 5 posts
  • LocationSouthern Illinois
Posted 10 February 2012 - 06:52 AM
Can I flash fastboot files on my phone using my phone? I'm stuck as well and I'm rooted with no bloat removed and update says fail each time I try. I've tried update the ota 9 times all failed and confused as to what to do. I don't even care if it breaks root anymore,I just want to update! Someone please help I have safestrap on not running any rom, running stock. What can I do to fix this? Also I don't have a computer so it will have to be done via phone.
#4 simon_lefisch
simon_lefisch
  • 265 posts
Posted 10 February 2012 - 08:38 AM
Try uninstalling safestrap then try to ota.
sent from my maxxed out razr on the other side of a wormhole.
#5 bullswife98
bullswife98
  • 5 posts
Posted 10 February 2012 - 11:51 AM
Already did that at around try #3 no good. Still won't update. I think safestrap changed my system.
b
#6 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
  • Twitter:@droidth3ory
  • LocationTroy, Michigan
Posted 10 February 2012 - 12:07 PM
b
If you were running SafeStrap, chances are you will need to replace your /preinstall DIR. 2 ways, via fastboot or root explorer.
There are a few threads around here on it.
#7 jdms2k
jdms2k
Posted 10 February 2012 - 07:55 PM
I too am having problems with being stuck can anyone direct me to the correct place i've looked but haven't really found anything thanks
#8 _base2
_base2
  • 810 posts
Posted 10 February 2012 - 08:28 PM
REMOVE safestrap via the APP itself. Don't just uninstall the app. Then I would make a backup of your apps in TiBu then RSD back to stock 6.11.748, re-root and restore your apps and data, and then use voodoo rootkeeper to protect su / root before you accept the OTA.
Boom. You're on 6.12.173 and rooted.
[ sent from _base2 ]
