so, i've had a maxx for two days now and i've noticed that the led light is off center from--not correctly aligned with and not directly below--the small see through, clear circle part in the black part of the screen at the top of the device. i assume that it is not designed to be that way. can you take a look at when your led is on and confirm that it should be centered/directly below clear circle part of screen.
when my led is lit, you only see half of the light...
=fail
thanks for the help.
Led Is Jacked Up
kochoid
, Feb 10 2012 07:16 AM
No replies to this topic
