Android Os Taking 50-85% Battery
Posted 13 February 2012 - 01:18 PM
Posted 13 February 2012 - 02:00 PM
Maybe try wiping and reflashing using Matt's Utility Tool.
Posted 14 February 2012 - 02:56 PM
Posted 15 February 2012 - 05:15 AM
I had originally written it off as the product of LTE idling, but the razr was on wifi all day yesterday and the maxx was on LTE, and Android OS usage is very high on both.
Posted 15 February 2012 - 05:54 AM
Posted 15 February 2012 - 07:25 AM
I suggest you download System Panel and Battery Monitor Widget from the Market. Together they will tell you what is eating up CPU time and how much power is being drained, and you may be able to isolate the process. BetterBatteryStats can help, too, if wake locks are keeping your phone from sleeping overnight. Also, Autostarts will help you prevent apps from starting up on their own when you don't need them.
Thank you. I don't think it's that though. CPU spy shows that sleep is not an issue. i am running battery monitor widget, hadn't put betterbatterystats on these phones yet but i will do that.
Posted 15 February 2012 - 02:48 PM
Check the history in Battery Monitor Widget. Overnight, with connectivity shut down, mine draws about 8mA.
Posted 15 February 2012 - 08:06 PM
I just snapped this screen shot.
And you cant see the bottom two, but it was Facebook 3% and Text Messaging 2%
I havnt used my phone a whole lot today and it was on 3G for 12 of the 14 hours haha.
Maybe 5mins talk time
70ish texts
15 emails
2 hours of Google Music (on 4g)
checking facebook thruout the day
EDIT:
On the stock ROM 2.3.6 (6.12.173)
