Rom Toolbox Question
oliohh
, Feb 14 2012 09:32 AM
6 replies to this topic
Posted 14 February 2012 - 09:32 AM
Sooooo ive tried multiple times to change my battery icon using rom toolbox, and it succesfully changes the icon but no matter if i pick the 1%, 10% or 20% icons, they all dont "synchronize" i guess the only word i can think of, they all go in 20% increments. like my battery will be at 90% but it will show 80...any ideas? Ive tried all sorts of diff icons.
Posted 14 February 2012 - 10:06 AM
Because the rom you are using is set up on 20% battery read out.
3.0 icsourcery GNex
Posted 14 February 2012 - 10:18 AM
Right now im using the stock rom. But ive tried on RazrX as well. I also tried it on my droid x and i get the same results
Well rom are you using and what battery icons you want?
Shoot me a pm and I get you a flashable zip with the battery icons
i appreciate the help but currently im using my old droid x, my razr broke lol. but i had the same exact problem on both phones so im assuming its something i have to do. wipe stats of battery or cache or something idk lol but i dont wanna just start doing random things
Posted 14 February 2012 - 10:24 AM
All i know is if the rom dont have the 1% battery mod it is not going to work. But mopar can fix u up
3.0 icsourcery GNex
Posted 14 February 2012 - 09:21 PM
I know stock only does 20% but its still not a problem.
Stock I believe can go to 10%
RazrX i dont know off hand, but would take much to fix either one.
id love to know how to change the stock to 10% so that i could see it in % instead of just the little battery. I use a market app to easily show me the % but id prefer if i could pick a custom battery. But either way ive found razrx to be my rom of choice so far, i downloaded a theme for it which made it come with a 10% battery icon but id like to know how to change it, cuz once i change that icon it auto goes back to 20%
