I am trying to replace Stock Blur contacts/phone with that of cm10... i replace and set proper permissions to rw-r--r--
contacts.apk
contactsprovider.apk
googlecontactssyncadapter.apk
phone.apk
telephonyprovider.apk
with its counter part of the cm10 but when i reboot it comes with a phone.apk forceclose... is there anything i need to change maybe build.prop or somewhere... please help.. thank you by the way
I need some help.
jvasquezhhi
, Feb 06 2013 01:06 AM
3 replies to this topic
Posted 06 February 2013 - 01:06 AM
Posted 09 February 2013 - 08:16 PM
I'm trying to figure out the same thing for the razr hd... I'll let you know if I figure it out. I'm still researching.
Posted 14 February 2013 - 06:48 PM
Had the same issue when replacing the moto email with the one from CM10. Wiping Dalvik cache and fixing permissions in recovery fixed it for me.
Sent from my Dev Edition XT907 using Tapatalk 2
Posted 14 February 2013 - 06:59 PM
Try deleting the phoneconfig.apk from blur base. I'm wondering if it and the phone.apk from cm10 base don't get along.
