Root for JB?
Posted 06 February 2013 - 05:55 PM
Posted 06 February 2013 - 05:56 PM
Posted 06 February 2013 - 08:36 PM
Posted 06 February 2013 - 08:44 PM
Sent from my Icarus HD BIONIC
Posted 06 February 2013 - 08:45 PM
- livinginkaos likes this
Posted 07 February 2013 - 07:30 PM
Posted 08 February 2013 - 10:09 PM
Posted 09 February 2013 - 03:08 PM
Nobody working on it that I know of.
Using rootkeeper isn't working for me.when updating through about phone, system updates it keeps failing
It will go through a few seconds and then reset. I am doing it just like on the of RAZR temp unroot then restore temp unroot then restore. Now.for the HD do I need to temp unroot or.be In the restore root mode for voodoo ota
Superuser binaries are updated to lasted version
Posted 10 February 2013 - 05:05 PM
Posted 10 February 2013 - 08:28 PM
You should be in the restore root mode when updating. Backup root, temp unroot, restore root, temp unroot, then restore root again. I know it seems pointless but give it a try.
Posted 10 February 2013 - 08:30 PM
Thought of going back but I dont have the time to redo everything again, just gona wait till someone roots jb before using TB to restore all my games and other saved data.
You might be waiting a while for the jb root option since there is the work around. I honestly doubt anyone will attempt a jb root at this point. But its up to you.
Posted 12 February 2013 - 11:11 AM
X2, I have had best luck with leaving it in 'Temp Unroot' state. I once did an update while VoodooRootkeeper was installed, but I forgot to Temp UnRoot, and I was stuck in a state where I had to start all over again.
Posted 15 February 2013 - 12:06 AM
