Home button
Posted 07 February 2013 - 01:28 PM
Posted 07 February 2013 - 02:19 PM
Posted 07 February 2013 - 03:09 PM
Posted 07 February 2013 - 03:23 PM
Wait, did you meant didn't fix it?
Posted 07 February 2013 - 03:28 PM
Posted 08 February 2013 - 02:52 PM
Posted 08 February 2013 - 04:18 PM
Posted 08 February 2013 - 04:57 PM
yupp exactlyAll the same apps installed as on AOKP?
Posted 08 February 2013 - 04:58 PM
Posted 08 February 2013 - 05:04 PM
well i have had this happen on a couple different roms (elipse, team haters, blurrymaxx) and now this and it always with the phone being really laggy and and then freezing and then all i can access is the power menu to reboot and then thats it doesnt work after such plus and my user preferences are gone as well (lockscreen is gone, unknown apps installed was unchecked, all my gui was back to "stock AOKP look") so ueah the only way i have ended up fixing this is wiping everuthing and starting from scratchDid you try getting a hold of an older version of AOKP and seeing if it is version specific?
Posted 08 February 2013 - 05:15 PM
I'd start looking at the apps you have installed and figuring out why the phone is getting laggy in the first place. That is by far not normal behavior, and since it keeps happening to you I'd look at the apps first.
Posted 08 February 2013 - 07:22 PM
i have looked through all my apps and they are only support apps or a few gamesThen it is not a ROM specific thing at all - this has obviously happened to you before.
Posted 08 February 2013 - 07:27 PM
Not sure what exactly is going on. But if it keeps happening across different ROMs, then it's either hardware or software. And if it is hardware then a reset should not fix it, so I'm inclined to think software
Posted 08 February 2013 - 09:31 PM
im going to wipe the whole rom slot and not ise any backups or any thing and rebuild the rom and see what happenesHas to be something. If this keeps happening repeatedly something somewhere is on the blink - even if it is your internal storage.
Edit: i redid the my home button works now i will let you know if it breaks again
- johnlgalt likes this
Posted 19 February 2013 - 09:03 PM
OK I just rebooted and switched ROMs slots to check something on my other ROM and my home button went out again
Posted 20 February 2013 - 07:04 PM
I wonder if it is because of files that are being yanked to make these ROMs smaller?
Posted 24 February 2013 - 10:14 AM
Posted 08 April 2013 - 08:17 PM
