Bricked my razr and can't access via fastboot and adb
Posted 09 February 2013 - 12:00 PM
- I tried to use RSD to flash JB fastboot
- RSD can't flash "ebr" file
- Battery ran out
- Charged battery directly using peeled cable
- Can't access fastboot via fastboot (waiting for device) and adb (device not found)
- And the screen is dead, although my computer does detect new device when plugged in, then plugged off simultaneously (it's like you hear the sound when you plug usb drive in your lab top (in) and pull out (out) as in [in, out, out, out, out, then stopped])
Any helps appreciate. Thanks.
Posted 09 February 2013 - 04:39 PM
Here's what happened:
- Battery ran out
come into chat room
