On Tuesday, My wife dropped her xt907 Razr M in the tub, and retrived it sa fast as she could. The phone was still on, and she tried several times to turn the phone off, but the device would not turn off. The phone would cycle through to the Android with a red tryangle. She then got a bag of rice and placed the phone in the bag within the first hour. When I got to the phone 8 hours later, I tried everything to get the phone to shut down? this did not happen. Today the phone will boot up, the power button will wake the phone, but when using the phone, the power button just vibrates when pushed. I also have realized that when
ICAN BOOT INTO RECOVERY, but my Voluime buttons will not allow me to toggle down V- or select fFASTBOOT.
I Have a Factory USB Cable and have access to Fastboot.
The Buttons not functioning has me stumped, should I take her phone apart to check around the buttons, or do you THINK the M is Shot????
ANY Ideas would be helpful.
Water Issues
chazall1
, Feb 14 2013 08:54 AM
7 replies to this topic
Posted 14 February 2013 - 08:54 AM
Believe In "Open Source"
Posted 14 February 2013 - 09:23 AM
I don't think fast booting is gonna do anything since it's water damage. I'd let it dry out as much as it can and u might get lucky. Maybe someone else has some more input. Good luck
Posted 14 February 2013 - 10:09 AM
you should have left in rice at least 24 hrs before you touched it,i think it's toast
Posted 14 February 2013 - 10:46 AM
wrap it in a towel put it in the freezer for 30 min. checking it constantly for any frosting on the screen. if you find any pull it out leave it out put back in the rice for 24 hours.
this is a huge issue with these devices make sure its hard keys are facing down while in the bag of rice. so that way moisture can be pulled out using the lovely force of gravity. .
beyond this yes its shot.
Posted 14 February 2013 - 10:52 AM
the phone actually could of/should of survived if when pulled out of the water was left alone ... not touched until dry (meaning not trying to shut it off or anything... by pressing the keys openned cracks that allowed water to filter in)... usually 24 hours in rice should do the job...
Posted 14 February 2013 - 04:47 PM
I will see how it goes over time? Thanks for the replies
Posted 17 February 2013 - 01:46 PM
any update?
Posted 17 February 2013 - 02:37 PM
Well Her M is out of commission! She took the phone to a local computer/phone shop and he indicated that the power and volume controls were bad? I knew that, and I did not have the ability to boot into phone recovery. I am going to mess with it my self, no pressure, and see if I can take it apart
