So I really prefer to have the screen stay awake while plugged in to power. In the developer options the "stay awake" function is greyed out and I can't check the box. Any idea how to fix this? My previous Droids have not done this to me...
"stay awake" option greyed out
puckalicious
, Feb 15 2013 09:53 AM
5 replies to this topic
Posted 15 February 2013 - 09:53 AM
Posted 15 February 2013 - 12:13 PM
Just checked mine and I can select it just fine. Are you sure you have Developer Options turned on? Keeping the screen on while charging may not be a great idea with an AMOLED screen though. That's asking for premature burn-in.
Sent from m Developer Edition RAZR M
Posted 15 February 2013 - 01:06 PM
Yeah, the dev options is turned on, but only the 'stay awake' option is greyed out.
Posted 16 February 2013 - 12:08 PM
need to be specific as to what rom you usingYeah, the dev options is turned on, but only the 'stay awake' option is greyed out.
Posted 16 February 2013 - 12:34 PM
Sorry, just running stock JB right out of the box. On my Bionic with ICS it is not greyed out.
Posted 16 February 2013 - 11:05 PM
im having no problem with it... have you tried wiping cache and such? it helps on some problems... if not i say fastboot bro..Sorry, just running stock JB right out of the box. On my Bionic with ICS it is not greyed out.
