Root Not Working For 2.3.6
7 replies to this topic
#1 oswall1065
oswall1065
  • 12 posts
Posted 18 February 2012 - 04:12 PM
I tried to root my Razr 2.3.6 with motofail but not working. How do I root?
#2 SoLongSidekick
SoLongSidekick
    YOU WILL HAIL!
  • 687 posts
Posted 18 February 2012 - 04:22 PM
Using motofail.
What method were you using? The direct method from Dan? Matt's tool? Which Razr model do you have?
We need more info than 'it didn't work'.
:-D :-D
#3 oswall1065
oswall1065
  • 12 posts
Posted 18 February 2012 - 04:24 PM
used matts tool my model is 6.12.173.xt912.verizon.en.us
#4 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 18 February 2012 - 04:36 PM
Do you have the errors it gave you when rooting?
#5 superrelaxx
superrelaxx
  • 921 posts
  • Twitter:jasNwa
  • LocationSeattle, Washington
Posted 20 February 2012 - 06:06 PM
I used your utility (1.4) to restore .173, then used option 2 to root 2.3.6. I also cannot root and this is the output:
Motorola universal root script ($version version)
by Dan Rosenberg (@djrbliss)
Tested on Droid 3, Droid Bionic, and Droid RAZR
Before continuing, ensure USB debugging is enabled, that your
device is in charge only mode, and your phone is connected via USB.
Waiting for device...
Device found.
Deploying payload...
3655 KB/s (359392 bytes in 0.096s)
Owning phone...
Waiting for phone to reboot.
error: protocol fault (no status)
Root successful! Persisting...
error: device not found
Cleaning up...
Rebooting...
Exploit complete!
Please make a selection or hit ENTER to return:
I ran Dan's Motofail and it was successful. I should have attempted to install/run the RazrBootstrap-v2.0.apk as a test to see if your utility worked regardless of the errors.
I am rooted now after running Dan's Motofail utility.
Edited by superrelaxx, 20 February 2012 - 06:26 PM.
#6 SoLongSidekick
SoLongSidekick
    YOU WILL HAIL!
  • 687 posts
Posted 20 February 2012 - 06:46 PM
Are you using the USB cable that came with the phone?
No one cares where this was sent from
:-D :-D
#7 jessesmith121
jessesmith121
  • 31 posts
  • LocationKansas City , MO
Posted 20 February 2012 - 08:10 PM
I am having issues as well. I cant get my phone into debugging mode. I am using the cable that came with the phone. I have the latest drivers from motorola and usb debugging is checked on the device... im on 2.3.6 this is driving me nuts...
  • oswall1065 likes this
#8 superrelaxx
superrelaxx
  • 921 posts
  • Twitter:jasNwa
Posted 21 February 2012 - 01:38 AM
I used the stock cable. Check out this link. This utility worked for me. Will give you root so you can install bootstrap or safestrap:
