Theme Help
Themes ICS
18 replies to this topic
#1 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
  • Google+:Lownslow200sx
  • LocationRocky Mount, NC
Posted 05 March 2012 - 04:54 PM
[attachment=1043:Screenshot_2012-03-05-19-39-36.png]
Trying to find someone to theme the loading Spinner to ICS blue
if anyone would like to help PM me.
#2 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
Posted 05 March 2012 - 05:11 PM
Where you at Bignadad :)
#3 Guest_24v_*
Guest_24v_*
Posted 05 March 2012 - 05:37 PM
What Rom are you running?
#4 mopar57
mopar57
    Developer/MOD
  • 375 posts
Posted 05 March 2012 - 05:55 PM
should be in framework-res.apk
and spinner_black_48 (20,76)
or spinner_white_48 (20,76)
Got an idea for a theme?
PM me!
I like mail! :D
#5 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
Posted 05 March 2012 - 05:56 PM
|AOKP B27 | AXI0M | KANG | RAZR | AB9
#6 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
Posted 05 March 2012 - 05:58 PM
What do you use to edit the png's ?
#7 Guest_24v_*
Guest_24v_*
Posted 05 March 2012 - 06:16 PM
Photoshop or Gimp.
#8 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
Posted 05 March 2012 - 06:19 PM
Photoshop or Gimp.
ok cool ill give it a try if not is this something you may be interested in helping with?
#9 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
Posted 05 March 2012 - 06:24 PM
If someone can edit the files and send them to me I know where to place them if that helps I can live without a flashable .zip :)
#10 mopar57
mopar57
    Developer/MOD
  • 375 posts
Posted 05 March 2012 - 07:14 PM
what color you want them?
PM me!
I like mail! :D
#11 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
Posted 05 March 2012 - 07:16 PM
ICS blue i think the code is #ff33b5e5
#12 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
Posted 05 March 2012 - 07:17 PM
Im playing with gimp now but its going to take me a while to figure out :)
#13 mopar57
mopar57
    Developer/MOD
  • 375 posts
Posted 05 March 2012 - 07:26 PM
OK here you go. Its not flashable, but i think this is what you wanted.
PM me!
I like mail! :D
#14 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
Posted 05 March 2012 - 07:38 PM
Thanks man its a lil different from what i wanted but i can try that till my gimp skills get a lil bit better. Im trying to take the stock spinners and change them from white to the ICS blue color and i also want to change the lock screen to the blue instead of white im just having problems with gimp :)
#15 Guest_24v_*
Guest_24v_*
Posted 06 March 2012 - 03:47 AM
Im trying to take the stock spinners and change them from white to the ICS blue color :)
That is what he gave you. The blue spinners. You just need to swap the images.
#16 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
Posted 06 March 2012 - 07:21 AM
Im going to try them out they just looked different from the look I was trying to get. I'll let y'all know how it turns out.
#17 eraursls84
eraursls84
  • 97 posts
Posted 06 March 2012 - 09:22 AM
I'd use paint.net instead, gimp gave me trouble saving icons with transparent backgrounds.
#18 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
Posted 08 March 2012 - 12:49 PM
Just downloaded Paint.net I'll let you know how it goes thanks man.
#19 Versatile1
Versatile1
  • 5 posts
  • Twitter:V3rSaTiL31
  • LocationTexoma
Posted 11 March 2012 - 05:47 AM
You must save as a .png also you must switch image type to RGB instead of indexed.
To get a transparent background I have found the easiest way for me is to:
1. Open image then select all and cut
2. Ctrl + L will open up layers window
3. Right click on background layer and choose delete layer
4. In the main workspace paste the image stored in the clipboard.
Hope this helps.
These instructions are for Gimp
Sent from my DROID BIONIC using Tapatalk
Also tagged with one or more of these keywords: Themes, ICS
